a/c removed and now overheating
cameronsclone
I removed my a/c a while back, and now I can't get the temperatures down. I plugged to two heater core lines from the block and radiator, soi don't think thats the problem. Tstat is good, flushed cooling system 2 times now, first used antifreeze and water, then flushed out again and went back to just water wetter and water. It has an e-fan also. When I'm getting airflow through it (ie above 50mph or so) it runs cool, but once go more than idle speed the temps shoot up fast. it ran above the 3/4 mark on temp gauge today, resulting in blowing out the radiator drain plug and puking water all over the street. Had a few mechanic friends say it sounds like a head gasket, but it didn't start doing it until after i took out the a/c, and the first day i drove it without it i started to overheat. I was thinking the fan but I'm not for sure. Can anyone think of what it might be?
Flyin Ryan
hated cuz he drives fords
Re: a/c removed and now overheating
Did you make sure the efan is working and turning on when needed or when you have it setup to turn on?
Removing the ac doesn't really have anything to do with the cooling system and I know I was able to data log boost runs throught out my neighborhood without my efan kicking on and never got above 194 (180 degree t stat) and with the efan it never seen 180.
SY2455
70's Veteran
With the engine cold and the radiator full remove radiator cap and look for bubbles. If you have bubbles, you most likely have a head gasket problem. When it starts to get hot, Does the fan come on? This is one of the reason to stay with the stock fan clutch and up grading to the 2001 GMC fan from a Safari. It has 11 blades vs the stock 5 blades.
cameronsclone
I have an efan on it, pulls an ok amount of air, and is hotwired with ic pump. I'll check for the bubbles in the rad.
Jimmy
Banned
Hmmm,anyone using one of these? Flow better?
GM #15976889 96-04 4.3 V6
cameronsclone
i flushed it and filled it again. ran for a lil bit to get all the air pockets and bubbles out, but no more bubbles after that. What else could it be? Maybe a new radiator? new fan? it doesn't seem to pull much air, but I don't know if that would make it overheat so bad like that.
IMHO Almost any air flow through the rad at idle will cool the engine. Something else going on. Air in the system is my first choice. With cap off and engine warmed is the rad full? Do you see flow? As mentioned if you see bubbles then there's a different prob. Really off the wall thought: After the AC delete you wrapped the belt around the water pump the wrong way. Pump going the wrong direction would mess things up.
Norm
I was wondering if he changed the water pump and had one with the normal vanes in it( non reverse flow). Just something else to look at. If it's still the same water pump then I have no idea other than head gasket or air pocket.
cameronsclone
Radiator is full and i let it run for about 5-10 mins and squeeze the hoses to try to get all the bubbles and air out. I'll check again, but I'm almost positive the belts are as it shows above the radiator support. Is there a way to pressure test a radiator or something? I'm still leaning towards that fan more than anything, I may go buy one from autozone and save the reciept, or just go to a junkyard and look for a high flow one.
SY2455
70's Veteran
You can do a pressure test on the cooling system if you have the tool. I'm using the 2001 fan on my Syclone, If you do a search you will find a posting about it.
SY2932
Administrator
BINGO. If you replaced the AC compressor with an AC delete pulley, the serpentine belt MUST be routed the EXACT same way that it was before you removed the AC. Just for $hits and giggles, I tried to route my serpentine belt the way that it was shown on the sticker on top of the shroud "WITHOUT AC" once after I removed mine. The belt could be routed both ways easily. However, using the WITHOUT AC path resulted in a VERY loose belt. It would probably barely spin the mechanical fan even though I didn't try to run the truck with it routed incorrectly. You have an electric fan(s) but, if the belt is routed wrong and is very loose, it may be slipping on the water pump pulley.
cameronsclone
oh wow yall are right. I just checked and i totally skipped that tiny free spinning pulley (i guess the tensioner?), and it was kind of loose. Not like floppy or anything, but not as tight as usual. I'm still going to invest in a better e fan though. The one i have only covers 2/3 of the rad, and i don't think it's pulling enough air. I'll see if changing the belt works tomorrow.
cameronsclone
would a loose belt also affect oil pressure? After removing the a/c oil pressure has been low. I changed the filter and oil, it's filled up. Still very low, even hitting 0psi when at low RPMs and the check engine light flashing.
jjorgensen52
NHSTE - I'm the only one!
That's not involved with the belts, you ought to look into that.
cameronsclone
none. it had check engine flashing when it got reaaallllll hot and i shut it off, but I think that was more of an "oh sh!t were gonna blow" code than anything. it isn't pulling any codes right now.
SY2455
70's Veteran
As far as oil pressure being low maybe your sender unit went bad. I would look into that 1st, test it with a new one. If it is ok you may need a new engine.
cameronsclone
update: wow I feel like a total dumbass. the belt was tight even without being on the idler pulley (underdrive size belt) so I was back to being stumped. Took out radiator and fan, powerwashed radiator and played with connections and ground on the e fan. When installing it again I hooked everything back up and all, then thought about the electrical connector for the efan. It is a prong and socket type thing (like a wall plug, but can go either way) so I thought well maybe it changes the way the fan works. Sure enough one way was clockwise and the other was counterclockwise. So the whole time I had been pushing hot engine compartment air into the radiator instead of pulling cold in. Didn't even seem like it was going in reverse, I just had to play with it. Finnaly runs again. Tied up a few vacuum leaks in the process of removing the A/C and it feels great to drive again.
Luke
Fish sticks SUCK !!!
at least it was something cheap and easy to fix, which is usually not the case
