A/F and timing advice...
GEN3Typhoon
In particular looking for input from Tony, Nolan and BG.. others I have not mentioned, if you guys have the time or the inclination.
What types of A/F and timing are you running at the following boost level on pump gas?
12-15-18-20-20+ psi
What about on race gas? (I use C-16)
18-20-22-25 psi
Any advice you can give is great.. .I am going to go to the dyno this week and tune some.. I have it set great at WOT for 12 psi.. 11.8 A/F running 20 degrees of timing with no issues. Plan on tuning on pump gas only this time.. just want to tune some higher boost levels and play with the timing.
Thanks for the help.. incidentally, Tony those DVD's are STILL sitting on my desk, I know I suck.
E-Rue
12.0-12.5 AFR and 20 deg
im not sure as the boost goes thru the roof, as i havnt tuned for anything over 20psi.
e
smeagol
I like 11.6-11.8 AFR to start, but *typically* you will make more power the leaner you get. I've yet to see a turbo vehicle make *significantly* more power changing from 12.2 to 12.5 AFR... but that's just in my experience.
These are some generalizations, every vehicle and combination will be different, as there are too many variables.
Timing-wise.. the vortecs, I'd run 15-20 deg on pump gas, 20-28 degrees on race gas.
Stock heads, pump gas 10-15 degrees, race gas 15-20 degrees.
Again, this will vary with the buildup, combination, octane used, but it gives you a starting point.
Many people tune the fueling then move to timing... but remember, if you alter timing heavily, and make more power, it will burn that fuel more efficiently, thereby leaning you out a bit. Just something to remember; I've seen it happen on the dyno. Also, if you are pig rich, and you run a lot of timing... you might get away with it, but if it's too much timing, the rich fueling may have masked an unsafe situation.
If you tune it to an edge on 104 octane, run 104 octane at the track, if you tune it on 116, race it on 116. Different fuels have vastly different characteristics.
Just some random thoughts.
GEN3Typhoon
Thanks...
I have the vortecs... seems to pull good where I have it. I have no numbers yet. Like I said 11.8 and 20 degrees seems great. It is correcting maybe 0.2 all the way through to 6000 rpm.
I will stick with 20 for now and maybe run 12:1 see how much power it makes... seems safe right now.
I appreciate the time.
ed hess
race or get outta the way
brian
could you elaborate on this:
reason i ask is i was only using 110 on t318 and when i tried t320 i got some kr (12.2et) that was more than a degree so i went back to t318 (12.1et).
I have this feeling i should be using 116 gas on all the t3xx settings as thats probly how you designed it.
ed
btw, only thing i know about octane is higher number = slower burn.
so with more octane you cant get the burn before its optimum time which essentially is the detonation when the time isnt optimal.
10secTy
Sy-Ty builder and Tuner
Sorry I am late on this I've been busy with the Big Dawg.
We have differnt pump gas than you luckey americans.
In other words ours Sucks. I run low 11 AF and around 14-16 degrees timing on pump gas at 14 psi. Thats all that our pump gas can take.
As for C-16 it loves timing. At first try 25 degrees and up the boost start at 20 and go up from there. As well I run A/F ratios in the 12-1 range with C16.
I have played with 12.5-1 and saw a increase in power but I like to tune on the safer side (and tony likes his motor in one piece) so its 12.1 to 11.8 on his.
Nolan
