a/f ratios
BigAl...
I'm in the process of doing some WBo2 testing and was wondering what air fuel ratios I should shoot for? I'm guessing it should be around 12.0/1.
TIA
BigAl...
Buster
You guessed right, not saying it'll make the most power at 12-1, but its a good place to start. I run mine a little lean from 0-10 psi to help get off the line, but after that 12.3 to 11.8.
Mark L
nightdiver
I got it 12.2 till 15 psi and 12 to 1 all the way up
In vac.till 3000 rpm is 14.5 and im going to lean it for more MPG
