I posted a question in the chip section a few weeks ago and for some reason that section is gone, anyhow I've got some info that might be old news, but I thought a few of you might interested in. My original problem was my a/f ratio at wot would change on a daily basis, and really run lean on highway kickdowns, I never consider mat temp, but obviously when your cruising down the freeway and your mat temp drops you'll need more fuel for a wot blast.
When Dig and I originally tuned my truck it was pretty hot out, MAT temps would start out in the 110-120 range and end at about 160-170. Dig tuned it to be safe, I'm not sure exactly what a/f, but some where in the low 12-1's, maybe even fatter. Anyhow a few weeks later Kris and I bought a wideband and I found my a/f ratio to be dangerously high, in the mid13-1's at wot. After making a few passes I've found that my a/f ratio is closely related to my MAT temp, at 80 degrees (at most rpms and boost levels) I'm in the 13.3-1 range, then at 111 degrees (at most rpms and boost levels) I'm in the 12.7-1 range, and then at 150 I'm in the 11.9-1 range.
Anyhow I think I found the right table in promgrammer (F31M) that controls fuel based on MAT, just thought a few might be interested in this info. I haven't started using this table yet, but only problem I see is it's kind of broad, I'd be sweet if Bill could added a few tables so we could adjust fuel a little more closely based on temp. If anyones using this table I'd like to hear about it.
Mark L
Mark L
