A heads up on Alky Controllers
James Thomas
"NO CLASS"
Re: A heads up on Alky Controllers
I read your other thread and I feel for you. I had a similar situation and was told about the same thing. I am a multi line distributor for many products (mostly Harley related) but many of them spill over to auto performance. I understand his point about opening the case as far as abuse if things were broken, cut, changed etc. inside the case but cutting an external wire or harness / just opening the case to see what was up and not mucking with it after you see the problem is BS. We mod wiring & harness wires all the time, it's called custom install?
I had a progressive NOS control that started acting up three days after install at the track while I was running the customers car. I opened the case and a cap was smoking in front of my eyes! Sent that baby back to NOS and got a call from some woman saying " sorry, we can't warranty this because your customer broke the seal. Would you like us to charge a replacement to you and send another one?". Informed her of the above info and that I was the one who opened it and the response was the same, "it doesn't matter who opened it, it was opened and warranty was void"!
Hmmm..... I think I need to speak with Mike please? I'm sorry, Mike doesn't handle warranty, I do that. So I went through the whole thing one more time and added that I am an engineer by trade and that it's ok, I didn't need to speak to Mike about warranty (was actually going to ask Mike if this gal worked for him or the idiot's at Holley and let him know his CSR was going down the drain if she treats all the customers like that) and that I would just contact him later AT HOME!
Forty five minutes later I get a call from a fellow named Steve who tells me "no problem, replacement on the way! I looked at it and opening the case didn’t cause the bad cap". Why did this happen you ask? Was it because I know Mike? Because I called him? No...... I didn't, Steve heard the conversation and thought "wow, guy says it stopped working, was in a bind at the track and didn't have much to loose, may have been a bad connection that could have been an easy fix and the fellow knows what he is doing, said the thing was burned and stopped right there to return it and nothing in the box was altered so" a little customer service may be in order here.
Bottom line, there are policies and for reasons..... agreed, there is also a thing called "does that make sense?" and a judgment call by good people that take care of customers. I'm sorry to hear you got the wrong guy and if you really didn't alter anything in the box, that he couldn’t take your word for the loose screws and that you know wiring. If so, you got shafted by the "blanket policy" many companies and people hide behind. I have had several complaints from other customers with dead / bad or intermittent Cooling Mist products that had similar comments about contacts with them. No details but I see a bad unit with no obvious damage and hear a complaint, I test it and sure enough it’s bad. Steer them to another known supplier of quality equipment, no more problem.
____________
James
Flyin Ryan
hated cuz he drives fords
I've read tons of theads on srtforums.com where the coolingmist guy puts down every single other alky injection company on the market like they never had a chance and don't compare in anyway possible to his kits especially his controllers :)
Even if that is true which im sure it isn't.. he doesn't present him self as a prefessional or a business owner.. More like a smart mouthed know-it-all punk which left a bad taste in my mouth when I was shopping around for my meth kit.. now in your thread on tb he actually seems like he's gathered more control over him self now which amazes me.
About your situation.. I think he should have worked with you some especially since you purchased two kits from him! I mean offer like a discount on a new controller or something to help prevent you from feeling like your being dicked
tealty
James,
Exactly! I could have been "sneaky" and tightened all the loose screws and put it back together like i was never in there. But since im too honest, I decided to just leave the loose screws alone and put it back together and see what he says. I guess i've learned my lesson with stuff like this. I hope this guy goes down and if I could sway one potential customer away from him, i'd be happy! Funny you deal with Harley parts, I have an 06 dyna that I fabbed up a custom turbo setup with alky inj and ended up making 150rwhp on stock motor with cam/JE's. I plan on setting up a water/air and go for over 250rwhp and high boost..we'll see. I'll blow the dang thing up if I have to.
Pimp,
Yeah this guy doesnt seem too professional especially when I talked with him through email. As a matter of fact, I actually had the third party seller (enginerunup.com), who I bought the controller from, offer me a new controller for $80. I told him no thanks I didnt want to risk another controller breakdown on my bike.
gmcturbo
i bet you he immediately condemned the unit when he saw the loose screw. business dont make money fixing sold products under warranty, all they are upholding is their good name while doing so. looks lke he doesnt care. sure sounds like he has alot of warranty returns also
