a little help
sygirl#1763
These are the mods I have now :
- Ultimate chip (50#)
- 50lb injectors
- PTE51 (kit)
- tranny cooler
- Derale deeppan
- 255 fuel pump
- AFPR
- Innovative Motorsports LM-1
Since I changed the stock turbo for the PTE51, I have no clue :oops: how much psi (turbo boost) this new one can handle. Same goes for the fuel pressure. Suggestions anyone ?
Angela
the new turbo will probbaly be able to handle upwards of 25 psi.
It all depends on your tuning on where you should set your everyday boost levels.
Put a data reader tool on it and start at base boost and work your way up from there till you start to see knock. Hopefully you should be able to get up to at least 17psi before seeing knock to really worry about.
sygirl#1763
Sorry div Lightning. Now I understand why you gave me this advise. Go from there you mean. Well that should be no problem cause I have Datamaster. Any idea for the fuel pressure ?
JustBeachin
Plays well with others
sygirl#1763 said:
Jimmy, is the 42 psi with the vacum on or off?
Base fuel pressure is always assumed to be with vacuum off. Otherwise it varies depending on how much boost or vacuum you're experiencing at that time.
Jimmy
Banned
Push the button in and pull the cable towards the driver's side,then twist the linkage to WOT.You will hear it "click" when you twist.That's it.
