A2A guys step in
Damian
Are any of you guys having engine cooling issues? My temps slowly creep up, and won't even drop if I drive down the freeway. I've tried an extreme duty fan clutch with the S10 Xtreme fan (plastic one), currently have electric fans, water wetter, high flow water pump, 160 degree thermostat, has a brand new S10 Xtreme radiator, fairly new radiator hoses, and no AC condenser. I have pulled the radiator cap off and there is tons of water flow at operating temp. The fans are pulling tons of air through the radiator. I even thought maybe the intercooler was too close to the radiator so I cut into the hood latch bracket and spaced the top of the intercooler towards the front with no change. Any ideas? I really don't feel like using a shorter intercooler unless I really have to.
ZavzTy547
Senior Member
Re: A2A guys step in
Sounds like a faulty thermostat. I'd check your thermostat as a first step.. . .
ajt86
Did you verify your temp sensor accuracy and gauge accuracy? Ive seen cars where the gauge needle was taken off and put back in the wrong spot.... and ive also seen plenty of temp sensors skewed... sometimes reading only 15* too high but enough to make you think you have a cooling issue
T-Bone
The fact water is flowing freely through the radiator with the cap removed rules out a faulty thermostat. My suggestion is to relocate the turbo intercooler. You have to realize that under boost, that processed air becomes very hot and while driving, your fans are simply pulling that extremely hot air right through a radiator that is already filled with hot water/antifreeze. Thus, instead of cooling the water/antifreeze, you are aiding in the process to overheat it. The only fix is to relocate the intercooler or go with a massive one so your air temps at that point of the vehicle stay cool. HTH.
0966Sy
Code what?
When you say hot, what temp are you describing cruising on the freeway? How big is your A2A and how thick? Bar or tube design? Also what shroud, electric fans on the radiator? What distance between the IC and radiator? If it is only getting hot under boost I'd say you might have choose an undersized A2A.
Damian
I have that big ass 3" one from frozenboost.com.
Even at idle, the temps won't come down. Driving down the freeway at 70mph the temps won't go down. The fans are pulling tons of hot air, so I don't understand why it's not cooling down. I also didn't see any air bubbles in the coolant with the engine running, so there goes bad head gasket.
And I have an Autometer coolant temp gauge, and data logging all show it's getting hot.
Damian
The temps creep up at idle, hold while driving, and creep up under boost. When I say hot, with a 160 degree thermostat, the temps can get up to 210. So before I shut the engine off, I slowly dump water on the radiator till it gets down to around 190. It's been slowly getting bad, but now it's annoying the crap out of me.
Here is my intercooler: http://www.frozenboost.com/front-mount-intercooler/turbo-intercooler-p-200.html
T-Bone
Damian, three other "possibilities":
(1) Some of the transfer channels within the radiator are plugged up. While it may appear to be flowing freely from atop, deeper down it is clogged from sediment therefore reducing the amount of coolant flow and subsequent cooling ability.
(2) Not at all trying to insult your intelligence (and your intercooler may be mounted correct) but make sure the inlet and outlet ports are placed at the bottom when mounted. Hot air rises and I have seen some guys invert the intercoolers to anable ease when routing the connecting tubing. The problem is that the hot air simply is passes right through without "rising" through the cooler fins.
(3) Water pump is on the blink OR loose serpentine belt (far stretch but possible)???
My electric fans didn't cool as well as the factory clutch fan and factory shroud. I have an A2A IC in the factory lower CCHE position.
My truck rely only keeps at 160 on a cool day or on the highway with the AC off. With the AC on on the highway my truck will reach 180-190. I probably would see 210 in traffic with the AC on. Your front mount IC is probably just going to make cooling worse. I don't know what kind of fans you but I plan on upgrading to better fans than I currently have. (Flex-a-lite dual fans)
ajt86
the E fans should have nothing to do with this, at highway speed, more air flows through the rad than the factory clutch fan can pull through- a lot of PCM controlled efans shut off at highway speeds
0966Sy
Code what?
210* is certainly hot, but not incredibly bad considering the size of the IC blocking airflow to the radiator. I would consider the distance between the IC and radiator should not be more than 1" to help the fans pull air across both. Having the outside edges of this >1" gap sealed will also aid in airflow.
Using a blowgun to assure your radiator has no buildup between the fins restricting cooling is a good check.
Test your radiator cap or replace it, a bad radiator cap will cause overheating. Let it idle up to operating temp and feel the upper and lower radiator hoses, they should feel the same in temperature at 160* confirming your thermostat is open.
Having your A2A core inverted is certainly not a "incorrect" way to install. Inlets and outlets can be up/down or center of the end tanks depending on design. If you are in question, contact the manufacture.
berzerker
wookie
do you have an coolant freeze point tester / refractometer ? possible too strong of coolant mixture ? delute your coolant ratio down till you have a freeze point of about 30-20 * since your in California no need for freeze protection concerns .
0966Sy
Code what?
Depending on shroud design, wether the fans are on or off. The shroud can restrict airflow.
ajt86
he said he is using water wetter, so I would think theres no coolant
Damian
I am using 50/50 mix, I added water wetter to see if it would help.
Stock fan and electric fans changed nothing.
I did just replace the radiator cap yesterday.
Everything appears to be working properly. If the engine is up to temp, the fans do pull HOT air through there. My problem is that I've seen so many people convert to A2A and I've never read about anyone having this problem. This thing can't even keep cool sitting at a long stop light. I just can imagine the intercooler is that massively restrictive that it won't even maintain a temp at idle. I could be completely wrong here.
berzerker
wookie
50/50 mix could equal a freeze protection down to - 50 * depending of the quality of the coolant . I have personally repaired dozens of class 8 diesel tractor engine overheating problems by simply dropping half the coolant out and adding straight water back in and setting the freeze protection levels to a more realistic protection level around - 20 * from an -55 to -60 * mixture that caused engine overheating issues . Water disperses heat quicker than than straight coolant . Give it try . And being your not in a climate that requires freeze protection it wont hurt anyway .
91blazins10
I had the same issue with mine. I ended up running a slightly thinner core and making my own shroud to make sure all the air was flowing through. That pretty much fixed the issue for me.
jeepruby04
What brand of t-stat are you running?
I had a Failsafe t-stat fail open like it should. This condition along with the high flow water pump may amplify the inefficiency of your cooling system. If the coolant is constantly flowing through the radiator without "holding" long enough to transfer the heat through the fins it will eventually overheat.
Damian
I'll replace the thermostat tomorrow or tonight and flush the system with water and add water wetter and see if that helps.
