atkonkler
Is this your bush?
Well I am doing this as a turbo removal/install write up/ port and polish/ write up all in one so it won't be perfect but hey if practice makes perfect and no one is perfect why practice. So here we go here's the start-- <a href=http://s1296.photobucket.com/albums/ag7/atkonkler/?action=view¤t=IMAG0370_zpsfdbd555f.jpg target=_blank><img
Wheel wells must come out the bolts are 13mm and there are 8 or 9 I do believe--
Remove them and you can remove the wheel well by shimming it down and pull it towards the left and down and pull it out.Then you can look like me!
Remove oil line from top of the turbo and be sure to soak the poop out of all fittings for coolant and oil for easy removal. Remove coolant line from passengerside of turbo. Remove out of way and drain coolant into drain pan and make sure your pets are not out and about because they might feel thirsty and drink it even if it's embittered. The remove oil feed line from top of turbo being sure to not bend or break the line because if you do your up secretion tributary without means of propulsion. Then go the the bottom of the turbo and remove oil return line the bolts are 7mm I do believe. Take off strap for the middle of the turbo that holds it together. Pull turbo forward and the other coolant banjo fitting can be accessed. It was a 18-19mm. I'm doing this by memory but so if I'm wrong you can slap me at nats. When I go one year. In the end it should look like this --
The next step will be to remove the housing from the Dp. These bolts were all 15mm . Three on the Dp and four that connect it to the manifold. Soak these little bastards and do the Dp bolts the make your way thru the Fender well and use a stubby 15mm for the pesky back bolts that you can get an normal wratchet or long wrench on. Also I found using the stubby and building on that with a long wrench will improve leverage after soaking the nuts and studs to break them free. Some studs may come out with the bolts. If they do yay! Replace them with a m10 x1.50x 25 stainless bolts thanks for the info Tom @Sportmachines If not just reuse your old ones. Remove Dp bolt that is down near the transmission so that the housing can be wiggled out and pulled off with ease. But remember to put that bolt back into its place first and to ensure you don't have the Dp rattling around. It should look like this when your done.---
Now with the next step I'm going to do what Ian did in his write up but include what I used for tools and part numbers. I followed Ian's
thread and used a piece of paper to shade over my old turbo inlet to get the pattern and use that to put onto my new turbo! Thanks Scottyblazinglow ! It will start out with using carbide bits and shaving the inlet like this!
. I did this until I shaved the inlet housing marker marks I made away with the help of Adam also!
Then
i polished the inlet by using 120, 80, 60 grit in that succession to a mirror smooth like finish! Like this
and Like this http://i1296.photobucket.com/albums/ag7/atkonkler/IMAG0390_zps6415424f.jpg[/I
INstall turbo back onto vehicle. But put bolt that holds Dp from rattling around first. The install turbo together. Check to see if there are leaks from oil or coolant lines. Now would be a good time to change plugs and do a compression check I might add! Go get some popeyes chicken and remember to check the god dam bag for all the condiments because biscuits just ain't as good with out the ****ing honey! Eat then go on a test drive and enjoy the beast it has become! I will be having a write up about how to correctly identify the housing you have on your turbo and dispel some of the myths behind the squabbling that goes on around here about how to identify the housing size so stay tuned! Hoped you enjoyed the write up it was my first and I am sure one of many to come!
Then
