? about inj pulse width
black cat
went tuning a couple of days ago. all seemed ok until i went over 15 lbs. the f29x table was up to 99. do i go to the f 77x table or are my stock inj running out. at what # inj pulse width do i run out.thks
Re: ? about inj pulse width
f77x table is one way to increase the range
f28 (egr table) is another.
You might be, probably not out of injector. You would need to look at the actual inj. pulse width being output and compare it to how much time is available which is dependent on RPM.
black cat
not a 100% sure how tell from rpm what my i would have left for pulse width. i,m used to other prog where u have inj duty %. i,m new to code 59 but i a vague to good idea what i,m doing.ps doesn,t the egr % affect the hole table. my f28 table seems alot higher than all the other bins ive seen for stock inj. i,m not too worried because everthing seems to be working fine.
