If I put on rear disc brakes can i retain the ABS Module and still have it work correctly. Does anybody make a kit to put rear discs on the truck instead of hunting them down in a salvage yard.
I just received a whole rear drum to disc conversion from SSBC. It does not have a place for the ABS sensor so will have to modify. Some people like to delete the ABS but I am reulctant to steer too far awy from stock. And you cant half uninstall the ABS coz if anything bad were to happen and the insurance company were to see a wire loom that was for a non existant ABS module, you may have some problems with a payout and find yourself in trouble. I can take pics of the hardware that is still in boxes if you forward me your email.
You can grind down the rear sensors to work w/ F-body brakes, but it is a fine line between getting the sensors thin enough and ruining them. 2nd gen S-truck sensors are much smaller, but would require a custom mounting bracket of some sort.
