ABS code 65
InvisiBill
"4WAL Control Unit or Motor Circuit - Check for loose ground at motor circuit or faulty ECHU valve"
Got pulled over for having a headlight out on our way to grab something to eat last night. Went to Meijer and got a pair of headlights, and on the way back went to Taco Bell. We decided at the last minute to turn in there, and the road was wet from raining all day. It wasn't a panic stop or anything, just quick. When we got to the window to pay, I noticed the ABS light on. I didn't notice it before that, but it could've been on.
I changed the front pads last summer, and open the bleeder screws when I did it. I've had no problems with it, including slamming on the brakes on the way to her house because some jackhole decided he just had to turn in front of me. Since I had just gotten pulled over, and still had a headlight out, I didn't want to do an ABS test last night.
Besides flushing lots of brake fluid through the system and checking grounds, is there anything else I can do? Any way I can specifically check to see if it's the motor circuit or the control unit?
InvisiBill said:
Oh yeah, when I read the codes, I did hear the motor(?) spin up, so I guess that eliminates that?
I get a similar code, basically Jeff Stabell (who work on the original design) said the ECHU valve is probably gummed up with old brake fluid. My motor pulse also, despite when reading the codes... though I still get the code.
InvisiBill
Well, I still appear to have ABS. It's hard to make yourself slam on the brakes, but I tried a couple times and they didn't lock up...
I'll probably flush things out, just to be safe. About how much brake fluid does the system hold? I have no idea if I'll need 1 bottle or 10...
InvisiBill
I just noticed tonight in my manual that to reset ABS codes, you jumper the diagnostic terminals for two seconds, unhook for one, then jumper again for two. I did that, and it went away and didn't come back.
InvisiBill
Doh, it came back at lunch today.
Tonight I ran about 20 oz of synthetic brake fluid through it. I drove it for a bit and it didn't come back on, so hopefully I've fixed it...
jdeangelis
I had this come up once before after I replaced my battery. Battery wasn't the problem. I had a corroded ground link just near the battery that I had knocked loose. Retightened and reset codes.
InvisiBill
Just a long-overdue update. After flushing the brakes out by bleeding lots of synthetic brake fluid through the system, the problem seems to have been fixed. I think the light still came on once or twice shortly after I flushed the system, but it's been fine since then.
jimmyz79
Re-Member
Bill,
Correct me if I'm wrong, but I thought that you can't use Dot 5 (synthetic) fluid on our ABS System???
I've had the same prob, but I haven't bled the system yet. I did reset the codes and the dash light has stayed off since.
InvisiBill
Yes, this was Valvoline synthetic DOT3.
I remember reading up on the different types a while ago. I think you just can't mix the two types. In other words, you can use DOT5, but only if you bleed out all the old fluid completely. It's been a long time though, so I might be wrong.
