exotickoncepts
N.A.S.T.E. Member
I had to use the brakes hard the other night because someone pulled out in front of me. Now the abs light and the brake light are on. The scanner says the abs module bad. I heard from ase classes that gm had a lot of problems with these. Any body know of an easy fix? I was told there is a gear that falls off inside the unit but the tech sheets say the unit is unserviceable. Has any body ever had one of these units apart? This is on my 91 sy. Thanks,
