ac hose assembly- HELP
Gnocide
turbo game burt reynolds
where can you find the correct one at?
not the dealer-
autozone or
advance
they all have a line that comes out of the back instead of on top for inter cooler clearance.
also what is the factory part number?
THANKS!!!
Re: ac hose assembly- HELP
I suspect used. Unless you want to go aftermarket.
NecroWolf
lost marbles member
i'm pretty sure they are a discontinued part and used or aftermarket are the only options
warmpancakes
dealer can get them but they are $$$$$ like 350 last i looked I have a nice used one here if you need it would need to be flushed
TY0618
I belive they were called something like "fitting, w/hoses" part# 12542245 for '93 Typhoon. they are disc., they were $370.00 roughley.......if I'm not mistaken.
I've got a nice low mile set I'll sell you if you want to go that route. I got them from T Bone, he said they came off Doc Hoovers truck. I don't know that for a fact, this is just what I was told. They appear to be real low mile though, because they are nice and dry where the rubber and the metal meet. If your interested, just PM me and I'll cut you a sweet deal on them.:tup:
Gnocide
thanks guys but-
the dealer does not have the correct one- and its $60 as of yesterday-for the wrong one
it looks exactly like the $48 ones from autzone/advance/car quest etc- and they are incorrect because of the metal line that exits the rear of one side instead of the top.
pooched!!!
unless someone can tig and re hose mine - im really Leary on used since they have a tendency to crack and leak from the compressor fitting
warmpancakes
The a/c lines are syclone typhoon specific its a dealer only on used last i knew they were obselete from the dealer
91blazins10
You can use a regular one from a s10, I had one on my typhoon and everything still fit ok.
91blazins10
with the stock intercooler?
Yep, It was like that when I bought it from the previous owner, it looked a little off, but everything still fit and worked fine. Ive since ditched the a/c and stock intercooler. Heres a old pic I found, only issue would be if you still have the stock air intake, it would probably rub against it.
Gnocide
hey pat that looks awful close to the inter cooler.you sure it doesnt rub?
anyway
thats the line you can get anywhere for $48 and is the one that the gmc dealer located for me in TENN LAST WEEK.still incorrect
and
that s10 line will not clear the atr inter cooler
s_blazin
i have never seen them get brittle and crack around the fittings unless they were really exposed to heat IE sitting out in the sun with either a hood off or off the car and sitting outside, other than that they don't really get much abuse.
i just added a/c back to 2 of my trucks using used lines and everything works great, so since they are discontinued new, and you will not find them NOS, your option is to either use a used one or don't use one at all.......you will not find a company that will reproduce them i guarantee.
