AC-How does the flapper for norm and max work?
cvcsmkr
mine is stuck open.
it is vacuum, right?
the only thing i can think of is that turrent looking vacuum selector behind ac controls.
chad
canadian
sy in progress
Re: AC-How does the flapper for norm and max work?
which flapper? i believe it's either vacuum operated or cable operated by the back side of the control panel.
Loeryder
The flapper that switches from floor vent to dash vent is vac controlled.
Check the line at the back of the upper intake going through the firewall.
Shoul
There is also a check valve inside the AC control pnael that is knownto leak.
That one you should be able to hear pretty easily though.
cvcsmkr
the flapper the either re-circulates air inside the cab(max) or brings air from out side (norm)
