Re: AC pressure switch
Funny, I just found this out doing the conversion a few weeks ago. We had a machine hooked up to see the pressures. Don't ask the numbers, sorry. (70 low 140 high? can't remember) What I did was to back out the screw two turns. Oops, didn 't work. Back in 1/2 turn, perfect. Watch the compressor clutch. At idle (not sure if that matters) AC on full cold, high fan, compressor should run about 50% of the time. Key word "about." But that's where I ended up and it works great.
Initially the clutch would just cycle on and off. That screw did the trick.
HTH
