AC Rapidfires
MYYellowTY
Anyone using these or used them before?If so any advice on them.I picked them up havent installed them yet.Wondering if I should go with the ND or AC standard plugs or even the Iridiums instead.Also I know the Rapidfires come pre set and your not suppose to touch it, but should I change it if its over .035 because of the blow out with these engines?And input is great.Thanks All!!!!
Cant belive how much improvement the ingition system makes a difference on these.WOW!! Changed cap,rotor, wires and gona do plugs but what a difference.Plus I think ill take the MSD 6A and coil of my Astro and put it on the TY!! :tup:
MonsterC
Re: AC Rapidfires
Which would be better on a stock setup? The ur5 or ur6?Im in San Diego and do short distance traveling mostly?Thanks!!!
Captain Morgan
Moderated User
Re: AC Rapidfires
NGK UR5 are the stock replacements, UR6's are a little colder plug but shouldnt be needed on a stock setup.
If you want Iridiums, then go with NGK Iridium UR5IX, Part # 7177, but for a stock truck, its probably not worth it
syclone1100
RUNNIN AND SELLIN
Re: AC Rapidfires
SY2455 said:
I use the NGK UR6IX part #7348 and they work Grrrrrrreat:tup:
Im using the same and noticed a HUGE difference!!! My idel smooth out and the ttruck runs way better!!!! I was using the standered A/C plugs those are junk and Ill never go back to them again!!!!
Jer
Don't taze me bro!
Re: AC Rapidfires
I have a set of RapidFires waiting to go in at my next plug change which will be very soon. They came highly recommended even though some on this forum said otherwise so I want to give them a shot.
Robert Lone
MUTANT
Re: AC Rapidfires
Some ppl swear by SplitFires too. :rotf: :rotf: :rotf: :rotf: :rotf: :robot: :rotf: :rotf: :rotf:
