Falco
Howdy,
Today I tried to diagnose a local Ty. One question here. The fellow tried to adjust his WG rod a few weeks ago but he did it the wrong way. He haven't loosened the nut and adjusted the eylet, but turned the whole rod wich turned around in the actuator's house. Since then the boost has been fluctuating between 9-17psi (stock chip) and the performance became worse. It was quite stable before, a bit on the low side.
Could he destroy the actuator? The spring seems to be working and the rod is around the factory specs (7/8th overlap). I tried to shorten the rod up to two turns (the proper way), but it did nothing. Also made a run with the solenoid looped out and it was solid 10psi all the time.
Now I've two trucks with boost problems to work on. Pls help if you can.
TIA,
TIA,
