Re: adjusting Fuel pressure
Did you check fp before you removed the stock regulator? IIRC, start the truck, remove vac line and plug it, loosed nut on fpr, adjust fpr with allen wrench to desired psi on gauge, tighten nut, reconnect vac line.
edit: stock fuel pressure is 42 lbs.
