adjusting wastegate rod?
atkonkler
Is this your bush?
Does anyone have experience with adjusting this rod? If its rusty how can you adjyst it? Its something ive never toyed with if anyone knows or has let me know!
Thanks Aaron
Davemc1963
93 Ty Owner
Re: adjusting wastegate rod?
Hi Dave for info, I adjusted the wastegate rod exactly as per the manual, with a DTI and a calibrated pressure gauge pressurised/operated by a mityvac (on the pressure side of course) The boost came on strong, but it overboosted all the time. I had to adjust the wastegate rod several full turns to stop it. I put it down to the 3" Cat Back, but dont really know for sure, as it isn't that much of a deviation from the stock set up. It had and still has the stock Cat fitted. I do plan on fitting some improved form of boost control, but in the last 12 months I haven't been able to spend much time on it except to do the front ball joints to keep it road worthy. Just thought I'd add this, it could be just my truck as I know they are all a little different, but it might just help someone.
