canadian
sy in progress
I've been chasing knock on this turd for years. My guess is that the balancer has spun but I haven't gone so far as to do the TDC check... yet. That is the next thing on the list.
I have confirmed that the mark on the balancer is in the correct spot on the pointer with the 2nd mark being at 5pm position with the tan wire disconnected.
I have set the fuel pressure to 42psi with the vacuum hose off and plugged.
This is a stock truck with over 100k on the clock. No mods other than some things turned off in the chip. That's it. Running 2 bar map. I have approx half a tank of 100 octane in it right now and did a quick trip down the street.
The issue is that I do see knock at idle after a quick stab of the throttle. In the quick blast I did, I confirmed that I'm getting 100% TPS. I can't seem to figure out how in TunerPro to get it to display the correct PSI that I see on my boost gauge.
I plan on doing some top end cleaner and switching the cap/rotor/wires this weekend if I get the motivation. I might even pull the rad to verify the balancer marks based on some information from DaveP that was posted in a different thread.
If someone could give the following file a quick once over to see if there is anything glaringly obvious I'd appreciate it.
http://www.warrenbowley.com/tunerpro/05242012.adl
Thanks
Thanks
