Wondering if this would work to use a newer 60e and keep the stock transfer case and all unmodified. Part No. 50-0405: In 1996, GM began producing a new version of electronically controlled transmissions called the 4L60E. This transmission is 21-1/2” long and has a removable bellhousing. The bolt pattern on the outside of the transmission is hexagonal, similar to the TH400 transmission. P/N 50-0405 takes the hexagonal bolt pattern and converts it to a square bolt pattern found on the 700R transmission. This kit comes with a clamp-on reluctor ring and sensor required for this transmission. With the new adapter bolted on the back of this transmission, the new overall length will be approximately the same as the 700R.
http://www.advanceadapters.com/prod...5e-4-speed-automatic-transmissionadapter-kit/
http://www.advanceadapters.com/downloads/50-0405.pdf
http://www.advanceadapters.com/pdf/gm_ebook.pdf
page 28 4l60e info
page 28 4l60e info
