Re: AEM Tru boost help
There super easy to set up if you don't read the instructions lol. Push and hold the two buttons for over 2 seconds. Should say something like program9 or so. Press the two again for another 2 seconds to get the the settings menu. To change the settings use the buttons one at a time. To go to the next setting push both buttons at the same time. It should be preset to run under the correct sensor and show psi not bar. I dont use the alarm setting but i put the guage light setting to afew pounds over my max boost setting i will run. Now just keep pushing both until you get to the spring pressure menu. They suggest that you put the spring pressure about 2psi lower than the actual spring. The point of this setting is when the wg starts to crack open. If you set this setting too high it will struggle to control the boost evenly. You can fine tune this if needed. The scramble boost setting will be the duty cycle first and time setting second. If you don't have this hooked up then don't mess with it. If you do, just remember that it uses a monetary switch. After all that you will get to the A pressure and then B pressure settings. always start low and work your way up slowly. Different wgs and springs will take duty cycle differently. Once you get that set, put the two buttons two more times and you will be set. Once your set, if you hold and press both buttons again, you can adjust the boost setting your at by simple pushing one button at a time.
