Afco adjustable blocks? pictures?
SYCLONE#1531
'MOFOFAST
I just lowered my front down on my truck 2 inches from lip to tire. I currently have 2 inch blocks in the back. (4.25 from tire to lip) I was going to add the AFCO Racing Adjustable Lowering Blocks to drop the rear down some more putting me at 2.75 from tire to lip in the back + the ability to center the rear.. Curious, does anyone have these on their truck and possibly have some installed pictures
Black Knight
I Glow Therefore I am
Re: Afco adjustable blocks? pictures?
Never even heard of them :popcorn2:
EDIT: Just looked them up.
If I'm understanding you correctly, you're going to stack them (the ones you have now on top the adjustable one)? If so I would reconsider that, as stacking blocks can cause axle wrap and is notorious for causing vibration problems.
Also since they're about $40 each, is it too much to consider spending more and getting dropped leafs for a considerably better ride?
SYCLONE#1531
'MOFOFAST
If I was looking correctly on the afco sight? The adjustable blocks were made to stack. I also found these 3 inch adj blocks on the speedway site.. These should do it for me...
cat-vi
Ty Wannabe
I've just installed the AFCO adjustable lowering block, they are by far as high as the one you picture here, but same thing, they look good, no problem to adjust the rearend in the position you want, I was able to center the wheels dead-on in the wheelwell, but by this the output-shaft from the transmission moved quite a bit out so I adjusted it back forward just a bit, I got some wedges under the lowering blocks, maybe I should find some bigger wedges to "rotate" the rearend forward, this should bring the output shaft further into the transmission again, I don't got anny pics of the lowering block as innstalled for know, but I can see if I'm able shoot some.
