Re: afpr help
Hi, is it the AFPR you are wanting to know how to set up or your AFR?
On the AFPR it would install just like the origional. You will need a gauge when you adjust to see what the fuel pressure is. You can get a guage that hooks up on the valve on the fuel rail that looks like a valve stem.
You just unplug the vacuum line from the AFPR and your fuel pressure by screwing the stud on top of the AFPR to the PSI you want. I think stock is 43.5 PSI.
If you need to adjust the AFR. Just post someone here will explain that also.
