afr at 11.0
AlaskaTy
as most of you know my truck's been running extremely rich lately. I got my wbo2 hooked up and am finally able to datalog; my afr is at 11.0. Obviously it needs to be tuned, but in the meantime I need to drive 200 miles to st. louis today and am trying to get my gas milage up from 8mpg! I tried backing down my fuel pressure all the way to 30#s and the ratio was still 11.0 at idle. Under throttle the afr is around 15, but once i get off it backs down to 11 again. Any ideas how to increase it until I have time to tune it?
leroy
Re: afr at 11.0
Your air/fuel ratio at cruising speeds will have a lot more impact on your mpg. 15:1 is a good cruise afr for now.
Jim
Lynn D. Brown
Re: afr at 11.0
11.0 is way low for idle - should be 13.5-14.0. 11.0 is about what U should have @ WOT, or perhaps asw low as even 10.5. Don't know how yours got backwards ? ECM screwed up ?
jwaller
Evil Genius/SyTy Guru
Re: afr at 11.0
what do you have to tune with? if all you have is fuel pressure then you cant change anything.
SBNova
Re: afr at 11.0
When you say under throttle is that reving it in park or while driving? There is a big difference between the two. My Ty idles at 14.7, and drives at 14.7 with a stock chip. When its started for the first time and the engine is cold it is richer in the 12:1 ranges and leans as the engine warms up like its supposed to. Was your engine cold when you checked??
AlaskaTy
Re: afr at 11.0
I had the afr on my comp while i was driving. When I was in the throttle (25-30% tps) it would read about 14.1 if I let off it would drop to about 11.8 or so. I'm in St. Louis and have no internet access at the shack they're putting us up in...I can give more info when I get back home. Thanks.
Re: afr at 11.0
Are you running open loop fueling?
