AFR at WOT
Buster
I've recently made a few passes with the wideband, at wot from a dead stop it's in the 12.0-12.5 range, but if I punch (100% tps) it from a roll the afr is in the mid 13-1 range. I don't understand how the afr could be so far off when It's at the same rpm's and boost pressure. Anyone else experienced this? Any solutions?
Mark L
10secTy
Sy-Ty builder and Tuner
Hmmmm could be that you do not have enough AE enrichment. Start playing with it by adding more AE. This is ok to do as you will not hurt anything by going richer.
Let me know how it works out.
Nolan
leroy
I agree with Nolan about the AE, provided you have enough injector, fuel pump/pressure.
Jim
10secTy
Well its all realitive. On pump gas at 14 psi with our shitty Canadian gas Tonys truck needs 11-1 at 14psi to kill any knock. :banghead:
With a good tank of gas the motor likes 12.2-1. :shocked!:
Marks motor might be different as deck heights, cams etc change things. Basically each motor wants a differnt thing and must be tuned accordingly.
Anyway Mark check you Fuel pressure does not drop like Jim said.
Send me a datamaster log
e-mail is TurboV6@telusplanet.net
Nolan Nykyforuk
Buster
Nolan
Which table in promgrammer would work best to add fuel in AE? I see there's two or three tables.
Do the AE tables affect PE fueling, because as soon as I punch it should be in PE, Right?
Mark
leroy
Quick fix is to add to the f37 (ae v. coolant temp) table. Try that first and see how it works. You could end up with some other driveability issues. For example, you could have a stumble or bog at off-idle, or other ae situations. That stuff can be fine tuned in the other 2 tables.
PE and AE make separate contributions to fueling. PE is more like the power valve in carburetors. AE is more like the accelerator pump. There's lots more in the P4 document about it.
Just my 2 cents.
Jim
10secTy
Play with the AE vs coolant temp table. Just increase the whole table and see if it gets better. :wink:
Nolan Nykyforuk
Buster
Thanks guys for the tip, the table came in handy after I rescaled everything. The problem was F-77 was basically flat between 1-15 psi, I was dumping in the same amount of fuel at 1 psi as I was at 15 psi, so it created a massive bog at low boost, at first I was trying to lean out in the low rpms of F61 which created the lean wot, anyhow I rescaled F-77, then fixed AE with F37, then worked out the bugs in F61. Still needs a little more work in F30, but it runs a ton better, no more bogs, wot afr is in the low 12-1 range, and I can even build some boost off the line, damn this great.
Mark L
