Indeed! No problem there is no detonation and runs very well but the question is because I like racing as safe as possible. I'm using methanol .. Greetings from Mexico
That is a bit lean (traditionally) when using meth. how are you changing your boost levels, with something like a manual boost controler? In my opinion if your sparying meth at those afr levels your ok.
There is nothing wrong with that AFR if the spark plugs show that is what the engine wants. Forget what you read on the internet - a lot of it is bull$hit!
