AFR PARK/Neutral TP ?
jaystcb
Sy 0902, 92Ty 0909
This morning I noticed somthing for the first time. So... hear is the story.
This morning (44deg out side) I started MySy and noticed that the AFR IN PARK/neutral was around 13.3
The AFR in Drive is around 14.7
(I did not notice a difference in AFR yesterday afternoon).
So after a short drive to work I had a coupple of minutes with TP to try and correct this issue.
I tried several different Tables to get a change in AFR with no luck befor i ran out of time.
Can someone lead me in the right direction? What Table should I use?
Re: AFR PARK/Neutral TP ?
So you noticed that the tune is rich during initial startup, in 44 deg weather? I would not be too worried about that.
Aeroking
e.i.
Most trucks do not like to idle at 14.7. The richer you go the smoother it idles, so richen it up until its tolerable. They are usually happy down around 13.0. Cruising at 14.7 is fine.
