Afr wot
Ty 1885
Re: Afr wot
I have it at 11.5 and it seams too rich, the truck boogs down. What is the afr on V2 ultimate ???
When i was running V2 it ran great on top end. I thinking of leaning it to about 12.3 and trying that.
bezerk
Re: Afr wot
without meth i would try to go as lean as possible, without getting knock. 11.8-12.2 seems to be good enough.
just_a_6
Re: Afr wot
if your truck is crapping out in wot at 11.5 A/F you to other issuses...
Ty 1885
Re: Afr wot
Talked to Cal at Hartline performance, he said that my bigger injectors 85s (he tuned it when i had 60s) that i need to lower AE/TPS range, getting too much fuel too fast.
just_a_6
Re: Afr wot
if your tuned for 60's and running 85's , then yes I'm sure it just dumping fuel, i quick retune and you should be good to go!:tup:
