Aftermarket gauges
nello
I just recieved a 3 pod from autometer for my SY (comes in black, not grey like your dash and no holes) got the electrical oil pressure and water temp autometer 2/16 "Z" series gauges to take the place of my dash cluster since I don't trust any the stock gauges.
Does anybody have some tips on installing these before I get started? Best wiring routes, where to get connected, ect. I haven't even taken them out of the box yet. I have some info on the oil gauge but how bout the water...just like everything else I've done on this truck, buy it and figure out how to make it work later. :lol:
Thanks.
hatrik8
Re: Aftermarket gauges
I didn't hook up oil and water. I used boost, trans temp and fuel pressure. But running the gauges is the same. You can just feed them through the corner of the dash down to the fuse box area. There is enough space there. If you want you can paint your pod to match, but it's up to you. Wiring the gauges is simple just follow the instructions and tap into the fuse box using some flat wire connectors. A lot of people go through the firewall under the brake booster. There is a grommet to punch through there or you can drill you own hole and install your own rubber grommet. As for installing your type gauges someone else can chime in with that since I don't know for sure. I'm thinking you can tap into your oil filter housing for the oil pressure.
