Aftermarket Headers, DP and WG
Lynn D. Brown
Hay Guys,
Anyone have any experience w the PTE 3" DP, PTE-63 turbo (no H2O cool) and upgraded stock WasteGate combo ? Vs ATR's Turbo (H2O cooled ?), DP and Ext WG ? Also any experience w ATR's Sy/Ty Headers and X-over ? PTE told me that their DP may not fit w the ATR Headers - anybody tried ?
I am looking for 500-600 HP and easy low 11's w a Bowtie. Isl the stock Exhaust Man & X-Over capable of this ? I know the GN ATR headers used up all of the room in my GN, and the aircraft clamps R a real PITA. I haven't heard good things about the Ext WG's, and I heard that U can't change all the plugs w the ATR 3" DP. Anybody got any experience w all this stuff ? Thanx ahead.
smeagol
I wouldn't call it an upgraded stock wastegate, it's an integral wastegate that is superior to the stocker for sure. I used a 63 to run 11.0 in my Sy. Tony from Canada just ran 10.7 with 26psi using the PTE exhaust housing & integral wastegate setup that is on the PTE downpipe (Tony made his own downpipe but he used the PTE upper section that bolts to the turbo). Boost control was damn solid with it. The ATR setup - I'm not a fan. The wastegate sucks, the 3-4 bolt adapter leaks (using the PTE exhaust housing fixes this), and it is difficult (or impossible) to get at the #6 plug.
The PTE downpipe fits with ATR headers.
I would have said no, but Tony just ran 10.7 @ 126 on stock exhaust manifolds.
I wasn't a fan of the v band clamp ATR enclosed with the latest kits, so I usually use a different clamp. V band clamps are nice IMO.
I'd go with the PTE setup. Headers are up to you, depending on budget. If you are doing Bowtie, it sounds like your budget is open. I'd only go to a Bowtie if I wanted mid 10s or faster.
ghettosled
SYTY SUPERSTORE
if you are having sealing problems with the V band clamps, you need a different clamp with a deeper groove to seal better. Or you can just tack weld a few spots around the edges. I love the V band setup. It is great, easy, clean, etc.
see my email Lynn for answers to your questions.
tyndago
My problem with the V-bands is a valid one that someone brought up to me.
The V-band is not a solid connection like a flange and bolts. In other words if you twist on it hard enough - it will open up and leak.
The motor is not solidily mounted so it moves around a bit. The exhaust is not solid either - but actually the stock downpipe is solidly mounted to the transmission.
A good idea would be a flex joint in the downpipe to allow for this expansion and contraction and to put less stress on all the joints....
UNIsackV6
Or use the flexible piping as a downpipe, the motor etc can move as much as it wants and it wont stress the connections at all, hell my entire downpipe and exhaust is the flex pipe, if its good enough for semi's its good enough for me :D
tyndago
Now you are making some - well probably pretty decent power - but for most I dont know how much I could recommmend a entire downpipe made from flexmaterial.
For the flex material to equal the flow of normal smooth pipe - I think you want stuff about an inch larger than the downpipe . Ie - 2 inch downpipe - 3" flex joint...
UNIsackV6
Good point, maybe even just do a foot or so of flex pipe and it will give you the movement you want, may even make it easier to change the plugs :wink:
tyndago
That and the V-band should make it so you could swing it out of the way enough to get at all the plugs....
Need to have plugs like the Skylines. I had them in and out about 5 times on the dyno...tightening the gaps up.... All on the top.... coil on plug style...
smeagol
Location isn't the issue, the wastegate design is.
A deltagate will bolt up in place of an ATR gate, but while it is better than the ATR, it is almost inadequate as well. Best bet is to weld up an HKS or Innovative gate if you have a problematic ATR gate IMO.
ghettosled
SYTY SUPERSTORE
yep.. and thats why I built my own 3" downpipe kit to bolt up to the PTE housing and use a large external wg like ITS Progate.
ghettosled
SYTY SUPERSTORE
I take the PTE housing and machine out the wg hole another .5" and had a flange made to match both the turbine outlet and wg hole. I mount an Innovative Turbo Progate similar to ATR location, and then its a 2 piece 3" mandrel bend back to the cat.
smeagol
Is your wastegate the Buick 3 bolt style?
If not, then no.
If yes, possibly still no. The PTE setup is *nearly* identical to the ATR setup, which is a 3 bolt Buick housing & 3-4 bolt adapter. So Mike's setup *should* bolt up to the ATR setup, but because of the slight differences, it may not work, someone would have to just try. If yours is a T3 4 bolt housing, I practically guarantee it won't fit.
kwick6
Looks like a 3 bolt buick style. It has a plate that the stock downpipe attaches to. I will probably have to pull it off if the high temp lube doesn't work. I might just send it to PTE, to have their wastegate put on, if it will bolt up to the .63 housing thats on there.
This is going to suck doing it at my house. Don't have all the bent wrenches and stuff to pull it. Oh well, gonna need to get this stuff sooner or later. Heard it might be easier if I pull the upper intake to get at the top two bolts.
Scott
ghettosled
SYTY SUPERSTORE
my downpipe must be used with one of my modified PTE syty housings. You will need to specify 0,P, or Q trim turbine wheel when ordering. Most of the TE/T series come with P trim. It eliminates the adaptor used with the atr style turbo upgrade and Gn 3 bolt housing (one of the main reasons for building this setup). My housing also has a .5" enlarged wg hole over the stock PTE hosuing.
So an answer to your question would be, yes it will bolt up to your TE44 but you will have to purchase the PTE housing and the downpipe.
