Sigo said:Who else makes reputable A2A's? I was kind of leaning towards KB as a decent maker of an A2A.
Pittman said:If they have any kindoff parts problem Im going to tell them to send me the prints and I will get the damn things made. Hell, I know a place in Denton TX that can make them by the thousands.
quote]
if you do this, please record the conversation. I would love to hear there response.
As for the dual core, if you are worried about heat i think the single will be enough. Due to the location of the second core, you will probably have more cooling issues b/c it blocks the radiator. I would say the single core is good to 600hp.
Due to popular demand i think I will make a new and improved bolt on a/a pretty soon.![]()
ghettosled said:Due to popular demand i think I will make a new and improved bolt on a/a pretty soon.![]()
ghettosled said:its pretty much going to be similar to the KB unit, but better piping, clamps, connectors, etc. Also a little cheaper
It's going to require re-clocking the compressor housing, and a hole in the passenger side fenderwell for the piping to pass through. You will be able to keep the stock radiator, ac, clutch fan, etc.
Pittman said:Another maker would be Charged Air Systems.
www.chargedair.com
Anyone have some actual data on the conversion?
hamrhead said:ghettosled said:Due to popular demand i think I will make a new and improved bolt on a/a pretty soon.![]()
Please do Mike!
If I may put in my suggestions. Please design it so that a minimum of cutting/hacking has to be done to install it, like the KB unit. Also, if possible, desigin it to work with both ATR & KB headers, along w/ stock manifolds. Being able to retain the stock clutch fan would be a plus. As far as cutting holes goes, I'd be willing to run pipes through my wheelwell panels, but I won't cut holes in or around the radiator support area.
