Keith, I emailed this to you, but thought someone else might want to learn.
Yes, I had this working on my Sy for over a year. On the cool side coming from the lower heat exchanger to the top side of the upper IC, I went to the heater core. So the hot from the Upper IC goes to the lower heat exchanger like usual. After the heat exchanger does its normal thing, the cooler water goes into the heater core before the IC.
The A/C system can have the air mixed over the evaporator and through the heater core. This is why you can have a little warm or a little cool. Well you turn on the A/C to Max or Norm and open the temp door to full hot (all the way to red). This allows the air to get cooled by the A/C and then cool off the heater core. The air inside the cab will eventually get almost as cold as normal air conditioning. After a pass or two, the heater water will be warm with IC coolant and the air inside the cab will be abit warmer.
If you live up north, you might be able to bypass the lower heat exchanger altogether. Of course the pump would still be needed, but the heater core might do enough cooling. I never experimented with it like this, but would imagine could work fairly well. This is all depending upon how well your A/C system works. HTH,
