Aldl cable issues was working fine
teamvortec
I bought a complete tuning set up from a fellow member and upon arrivals I couldn't get the aldl cable to work. I remembered I had and old cable at my shop so I grabbed it and hooked it up and it worked. Well I never could get the cable that came with the set up to work. Now a month and half later my old cable won't work. I have done several logs and haven't messed with the old cable in a few weeks. What could cause the laptop not work. When I try to log with datamaster if I test com everything is happy. When I got to monitor or strt recording it say PCM sync failed and never reconnects. If I try to connect with tuner pro it say connection failed. What ges me is one Sunday I did several logs fine but when I get back home Friday it gives me these alarms. The laptop I use stays in the typhoon and I just save the logs to a USB stick and read the logs and make any changes in tuner pro on another laptop ten transfer then back via USB stick. Anyone have any ideas?
IGottaSy
Re: Aldl cable issues was working fine
Cable connection to laptop serial or USB?
I had a similar problem trying to run DM and re-installing driver solved it.
teamvortec
I am using the ALDL - USB cable. I hooked my Solus Pro up and it reads the data fine.
teamvortec
I tried it in the begining and never could get it to work. But after I started having issues I tried again and couldnt get it to work. When I plug the cable in to it I never see it assign a com port to it in the device manager. So I wasn't to worried as I was going to just use the other that was working, but now it wont work either. It is using com3 for the aldl cable, I tried changing it to com1 no luck so I put it back to com3 and still nothing.
IGottaSy
That's what I was getting until I re-installed the driver for the ALDL cable. Im not a computer dude but it worked. Seemed like driver was not even there. I don't like Windows Vista.
teamvortec
I am goin to try that in a few minutes. The laptop I bought for the Typhoon has XP my work laptop has windows 7.
IGottaSy
Hope it helps. Serial port has the upper hand on this set up. Plus it screws in place.
fivetodrive
CRISPY
This may help...
Connecting DataMaster (or any scan tool) to your truck the first time can be very frustrating and difficult. Unless you have your settings just right, your truck's ECM won't "talk" to your laptop. The worst case scenario is attempting to use an adapter between Serial and USB. If your laptop has USB ports, get an ALDL cable in USB style. If your old laptop has no USB and only serial ports, use a Serial ALDL cable. Try to keep it simple with as few adapters as possible. I can't tell you how many hours I have wasted just trying to get a truck and a laptop to connect due to issues like this.
One critical tip for connecting DataMaster: the "ALDL Link Timing" needs to be adjusted after DataMaster is installed, from the default value of 0, to a final value of between 190-210. My truck "likes" 196. Some trucks won't connect below 200-203. You have to experiment and find a setting that works best for each truck.
This can be found by clicking the File menu, Record ALDL Data..., then click Options, Advanced..., Serial Communication Timing...
Copied from powertuneplus.com
