Re: aldl interface without 12 volts.
I did made the RS232 interface for interfaceing my from RS232 <-> Chevy 5.7V8 1995 from this page :
(but with external power supply from cigarette lighter socket)
http://www.techedge.com.au/vehicle/aldl8192/8192hw.htm
But when i connect the interface to the PC (not to ALDL just first measure things at the "M" wire which is supposed to go the to DATA line on the ADLD connector vehicle) i measure only around 3.0V at that wire (without starting a datalog software) and when i start e.g. freescan i measure around 2.7V.
Shouldn't that wire measure only 5.0V or 0.0V (logical 1 and logical 0) i though the max232 only make 5V or 0V to that interfacing pin?
I do measure 5Volt after the 7805 regulator so that's ok and i measure around 5.0Volt at pin 12 before it reaches the diode.Is anything wrong ?
Thanks in advance & pardon my bad english (i am dutch)
