ALDL to USB wiring
H-TOWN-TYPHOON
You're killin' me, Smalls
I am looking into installing a usb port into my truck for use with tunerpro. Anybody know of a schematic for ALDL->usb?
Am I just not searching with the right terms?
PPI Typhoon
DIY Madman
Re: ALDL to USB wiring
There's really only a couple chips out on the market. Just get your hands on an ALDL > RS232 schematic, then integrate that chip. Supporting parts are few.....like 3 or 4, otherwise, it's all in that chip.
SBNova
Are you looking for a ALDL cable thats USB, or are you trying to add some kind of USB port into your truck? There are only a few USB ALDL cables made. Try Moates.net, but you need two parts for it. Otherwise good luck if your fabbing something. If it works post a schematic so we can learn from your experience.
James Thomas
"NO CLASS"
One of the members here has done this, Hmmm...... Mr.King, Ed Hess? I can't remember for sure but I saw the pick of their dash when they posted it. Maybe this will ring a bell and the rightful "hacker" will chime in :lol: !
Inquiring minds want to know so how about it :tup: ?
____________
James
H-TOWN-TYPHOON
That looks like one of the PPI boxes that's been screwed to some abs. Otherwise, I wouldn't think that the rs232 would be attatched to a piece that is screwed to the abs.
That setup is similar to what I want to accomplish, except the port under the dash will be usb instead of rs232.
Right now I think that I will use the akm max232 schematic and instead of soldering in the female rs232, place posts and mate that board with this one.
http://www.mouser.com/search/refine.aspx?Ntt=626-DLP-EVAL232R
place both in a plastic "project box" and either mount the box where I can get to it or shove it under the dash and run a male to female usb adapter and just run that cable to an accessible location in/under the dash.
I constructed the "sneak peek" cable that uses 2n3904 xsistors from and had constant com problems. At first I thought that it was flawed construction, but then I mocked it up on breadboard and still ran into the same problems. It would have been nice to get that one going, as the components can be packaged in a much smaller case.
