Alky kit, $50 plus shipping, SOLD!!!
sy2206
**SOLD**
Hey guys, I'm doing some more cleaning in the garage, so I will have a bunch of misc stuff up for sale. This is one of the first things. This is one of the "Mark Larson" alky kits he sold a few years back. The pump, one hobb's switch, and some fittings are used. A few fittings, all the line, and one of the hobb's switches are brand new. You get everything in the picts. The lines, pump, fittings, filter, 2 nozzles, pressure gauge, 2 hobb's switches.
$50 plus shipping. Shipping anywhere in the lower 48 states is $10.
DMTY
Re: Alky kit, $50 plus shipping, PICS!!!
Any directions, or is it pretty easy to figure out?
Raist103
if everything is guarnteed to work send me a shipping quote it is sold.
WHITE.TY.MN
hey man if he falls threw I will take it
BoostedSUV
Damn... Not quick enough to jump on this! I probably would have paid more than double for an alky kit...
sy2206
Yeah, it's pretty straight forward. You'll need a resevoir, or you can use your stock washer fluid tank(thats how it was hooked up). The big line goes from the tank to the pump. Another piece of big line from the pump to the filter. A piece of the medium line from the filter to a "T" fitting. The "T" fitting has 2 outputs that use the small line. Run 2 pieces of the small line to the spray nozzles, and you're good to go. The hobb switch gets mounted somewhere in the intake, or T'd into a vaccum line. When the hobb switch see's boost pressure, it turns on the pump and on goes the alky. I do believe the 2 hobb switches are for different boost levels. I've never had the switches hooked up, so I'm not exactly sure what pressures they turn on at. If I remember correctly from Mark's personal truck, I think he had some that turned on at 10psi and some at 15psi.
It will take a little work to get it all put togather. Depending on how you set it up, and couple fittings will need to be moved around, you may even need to buy a fitting or two. It all depends on the configuration. I would say that this is not a 100% plug and play system, you will have to set it up and plumb it all togather. However, in my opinion, anyone with a basic mechanical knowledge should be able to figure it out. Most alky kits that are a "plug and play" go for $120 or more. This one is priced right, for the person who can spend a few minutes and put it all togather.
I put 12v to the pump and it fired right up, so the pump works great.
I guess I should also say that this kit is sold AS-IS. There are some risks involved with running an alky setup. If you're in boost, and the pump fails or a line gets clogged, it could case detonation that can hurt the engine . I think we all know that, but just throwin that out there....
sy2206
I sent a PM to DMTY to see if he's interested. He didn't really say either way in his post. Logic tells me he's interested, thats why he replied with questions. :)
Raist103 is second in line, White.Ty.MN is 3rd.....
Raist103
just got back on send me the shipping quote nj 08021, my buddy needs it.
