ALky Kit Nozzle location question #2
LandryPoole
Hey, what benefits, or lack thereof, or whatever, would there be in putting the water injection nozzle before the IC? I've got mine just after the turbo. Was wondering if it matter so much. I'm figuring that the air coming out of the turbo is hot, and the water injected right there would cool it down before going through the IC, which would help the IC keep from getting heat soaked. It just seems either way, in front or in back, it should make much of a difference. However, I'm hoping that someone who KNOWS, can help me on this one. Should I leave it, or should I move it, or since it is already there, should i just accept that I might loose a little. Thanx for any input on this. :roll:
Bill Z
Re: ALky Kit Nozzle location question #2
I have been told that there is a small chance that if there is any calcium in the water you are injection it will deposit on your IC if you place the sprayer before the IC. I guess you could spray only distilled water. More expensive. The calcium won't hurt the engine. With a pure methanol spray, the fear was that it could cause corrosion in the fins of the IC.
Just what I've been told.
LandryPoole
Yes, the corrosion part I was concerned about as well, running meth & Alky, but then that gives good reason to replace said IC with bigger IC. The only other concern I was told is that if the truck backfired for whatever reason the IC then would be a big fat bomb under the hood. That is kind of nerve racking to think about. But for now, I'll leave it as is. But I will be moving it very soon I think. I'm just going to run straight water for now, IE Distilled water that is, until I move it, which will be after my 10n1 is installed.
Daron
I have done both; a nozzle at the outlet of the turbo and one after the IC. I talked it over with Bruce P. and we agreed that benefits from better alky distribution in the charged air gained from placement at the outlet of the turbo, are likely negated by the mixture going thru the IC. The fine mist that is shot out of the nozzle and then "flashed" by the hot air, likely hits relatively cool fins in the IC and is stripped from the air; resulting it larger droplets being pushed off the fins and then into the intake. Its just a theory, one that is/was not expanded upon.
Practically speaking, I don't think (cant remember) I noticed a reduction in MATs comparing one or the other.
This and other issues are what drove me to delete my CCHE and just run Alky as my sole form of intercooling.
Jer
Don't taze me bro!
After. Let the FMIC do it's job to the best of it's ability then hit it with the alky. I'm also not fan of alky pooling up in the intercooler. The way I see it there's more margin for error further downstream. Not to mention that it will be easier to tune since what you inject will be RIGHT at the engine instead of a little lag downstream... every little bit helps.
How many NOS kits have you seen mounted that far downstream? Not the same but similar principal when injecting another liquid into the engine.
