djwaggoner
Installed Razor's Alky kit this week and discovered a way to keep the vacuum ball under the battery tray.
The ball must be moved as far forward as possible - against the bulkhead between the headlight and the radiator at an angle so that the ridge on the ball goes in the corner. Drill the new holes and mount w/ the original bolts from below. Wires and even IC hoses will clear with some minor adjusting.
Now position the pump on a towel or shoprags with the mount facing up - pad it enough that the pump is held firmly against the bottom of the tray. Make sure to pad the ball and fenderwell to ensure clearance when the padding is removed.
Place the battery tray on top and mark the position of the pump mount thru the hole in the tray.
Take it out and drill the mounting holes positioning the mount according you your marking (I only did 3). In order for the lip on the mount to clear the recess in the bottom of the tray, the tray will need to be flattened w/ a BFH where the pump-mount interferes. (You 'could' relieve the lip, but it's for rigidity of the mount).
Mount the pump on the bottom of the tray.
Then the tray can be reinstalled and the pump hooked up & wired.
The exit-point for the alky supply hose will need to be cut away or flattened for clearance and the wires can run thru the narrow space between the tray and the inner fender.
When it's all assembled, it looks like this from below with the fenderwell removed.
I wanted to keep the battery tray to use as the base for a CAI box - the sides were cut from 1/16" aluminum & assembled w/ pop rivets and self-drilling sheet metal screws. Aluminum angle was used at the bottom and the corner. Turned out functional if not pretty, tho' the K&N I had from the KB CAI was so long it sticks into the fender...A shorter filter will help.
HTH someone else...for bigger pix you can click on them.
