Basically the question asked in the tread is what afr should be ran with methanol, 12-1, 10-1 or 8-1? According to Derek, which I'm sure is correct, you just tune to 12-1. Basically he's saying it doesn't matter if your running gas or methanol you'll still be tuning for 12-1, even know it'll take nearly 2.5 times more methanol to get the same reading on the WB sensor.
This will make tuning a breeze, in the beginning I was under the impression I'd need to figure out my exact gas to meth ratio at every boost/rpm level and shoot for a different afr. See I'll be injecting 3-4 1- mm nozzles at say 7 psi, at this boost level I'll be running almost all alky, but then as the boost goes up so will the need for extra gas, changing my alky to gas ratio at every boost level.
So the game plan now is to dump in the alky under boost and start pulling fuel until I get a nice flat afr, hopefully I'll be able to make the big boy hp (70 series with 25-30 psi) without completely reworking the fuel system.
