Alkycontrol Intermittent
Sean Krupa
Moderator
My Alkycontrol kit is about 1 year old. It has been working great for the past year. Recently I've noticed that sometimes the system doesn't kick on. I have the Red LED pressure bulb on the Pillar pod so I can see when the kit comes on and has full pressure. Today, it doesn't come on with Boost and also the Meth in the tank didn't go down. I did some DM runs yesterday to get ready for the Track Friday, and today the Alky kit won't kick on. I can manually kick it on by hitting the Test button and the engine bogs down, but won't kick on with Boost.
I calld Julio about a month ago about the same problem and couldn't seem to figure it out and it worked a day later without touching anything. I've checkd the wires to the MAP and vacuum hoses. I've also checked the voltage going to the Black controller box.
If anyone has any suggestions, please LMK. I'm scheduled to race at the Track Friday and want to figure this out ASAP. The kit was just working yesterday just fine.
Thank You
Re: Alkycontrol Intermittent
One of my terminal block screws was loose on my Alkycontrol kit up under the dash. I would verify all the connections.
Sean Krupa
Moderator
Well I seemed to have fixed the problem somehow. I cleaned the grounds and fuses. I also adjusted the Turn on point in the Black box to add more voltage. Hopefully the problem is gone for good.
92TyLA
Nice, hope you hit those 11s - low 12s Sean
Video please:tup:
Sean Krupa
Moderator
The problem is back again. The Alky kit has been working everyday since I went to the Track on 6-8-12 (It didn't work when I went to the track). I called Julio before the 8th and he was on vacation for a week. I'm going to call him tomorrow and try to figure this out once and for all. I've never heard anyone else have a problem with this kit and it's really frustrating me.
Luckily the Red LED turn on light is on my Pillar pod so I know when it turns on or not so I don't blow the engine.
Have you checked the wire that connects to the MAP sensor? This one wire tells the Alkycontrol everything. That connection should be a solder connection.
Also do you have DataMaster? If so what does the boost trace look like? Might be a faulty MAP sensor or a leak in the line to it.
Sean Krupa
Moderator
The Green wire to the MAP is soldered. My boost is a straight line with no fluctuation and if it was a faulty MAP, the truck wouldn't run right. I had a faulty MAP last year and the truck would barely run. I have the Green wire for the Alky kit spliced into the ECM MAP sensor. I have another 3bar for my Boost gauge.
