am i obsessive
warmpancakes
I removed the level control on the Ty (it didnt work anyways) well tonight while installing the swabar I noticed I never removed the harness for the compressor, nedless to say i just spent an hour removing the entire remains of the harness:roll:
13Pelle
Re: am i obsessive
Why does it seem like everyone removes these?? Is it cause they are not working or people just don't like them?? Just curious.
:squint:
Jersey 91/93
NASTE Member
Re: am i obsessive
You are obsessive, but so are most of the rest of us. My compressor is still back there (along with the harness obviously), but pulling them out is on my everlasting to-do list.
MRKING
New Parts for Old Trucks
Re: am i obsessive
Good thing no one else saw that before you got to it . close one.
attackdog
Re: am i obsessive
:squint:
Anyone chime in if I am wrong on this one! They either stop working or when you want to lower the truck, it will raise the rearstill and run constantly.
-Dean
TYTILIDIE
METH HEAD
Re: am i obsessive
Yeah I found that thing to be obnoxious. I did the same thing when I pulled mine out.
sy2206
Re: am i obsessive
LOL, I'm glad I'm not the only one..... I do things like that all the time. Here's a few exacmples that come to mind....
When I rotate the tires on my jeep, I always put the one locking lug nut on the wheel stud facing the valve stem, so all four corners are the same.
When I put the center caps in the BBS wheels on my Shelby, I rotated them so the logo is always parallel with the ground, when the valve stem is exactly down.
When I mounted the tire on the BBS wheels, I rotated the tire on the wheel before it was beaded up, so all 4 tires are clocked the same on the wheels. So the letter Y in Yokohama is right by the same spoke, on every wheel.
Needless to say, I definately would have taken out the harness for the ABS. I'll be removing the ABS and the harness from my truck soon....
warmpancakes
Re: am i obsessive
I remoed the harness for the abs along with the sensors and replaced the hubs so the rings arent there
MikeRenz
not stock
Re: am i obsessive
shouldn't you put it opposite of the valve stem to offset the weights and keep the hub in "better" balance? :lol:
Black Knight
I Glow Therefore I am
Re: am i obsessive
OMG, I thought I was the only f~~king nutcase that does that $hit, now I feel a little better.
SY2932
Administrator
Re: am i obsessive
I KNOW that I am. Had to see a shrink for it when I was younger...
Switches for my gauges and TCC lock up (this was done several years before I became a CNC guy):
"Dremeled and hand filed to within .003" for a tight fit."
"Switches installed".
Re: am i obsessive
I did a set of header in my Corvette. After finishing it up and plugging back the sensors in, I realized their coolant sensor wire was bolted into the side of the block to keep tucked away. I could have just zip tied, but I want it done right. I ended up pulling the passenger side header out. It took me 2 hour to do one 8 mm bolt.
