Am I Running Rich, or Lean?
Ok, so I installed my new AFPR tonight and set base pressure at 32PSI. Now I'm using a Snap On brick to read my data, and I know everyone is going to tell me to get datamaster or something similar, but it's not in the budget right now so the "brick" will have to do for now. :) I was running late so I didn't get to test drive and get data, but I did get it to operating temp and let her sit at idle for a while. Now my ? is, my block learn is 124 and my intergrater is around the 150's and it stays there. My AF is 14.7 and my O2 voltages are fluctuating high and low (not exactly sure on ranges, but nothing jumped out at me) so what do you guys make of this??? All maintenance has been done, new vac lines, fuel filter, etc.
once again
intergater 150's
block learn 124
Air fuel 14.7
O2 changing
Oh yeah, the only "upgrades" to the truck are the AFPR, and 50 lb injectors (bought because stock ones were leaking and figured get bigger for future) :tup:
any help would be greatly appreciated,
Dewey
QUICK STORM
B.A.M.F. BMW Tech
Re: Am I Running Rich, or Lean?
i would set the fuel pressure to 40psi, pull the ecm A&B fuse with key off to reset integrator and blocklearn. O2 should switch between rich and lean while in closed loop and 14.7 is stochiometric.
James Thomas
"NO CLASS"
once again
intergater 150's
block learn 124
Air fuel 14.7
O2 changing
Dewey
Uh..... you say "the only "upgrades" to the truck are the AFPR, and 50 lb injectors". You do have a chip or tune that is calibrated for the 50lb. injectors right.......... right?
______________________
James Thomas
SY756
^^^^^ What James said. You've got to have a 50# chip if you're running the 50# injectors.
SBNova
Im not familiar with a snap on brick, but if your just scanning the ALDL stream you cant determine what the A/F ratio is. Maybe youve got a WB, but I didnt read it that way. I think it shows "commanded" or "desired" fuel ratio, but a stock narrow band wont give you an actual A/F ratio through the ALDL.
Lowering your FP is one way to help compensate for using larger injectors, but its not the right way. Injectors dont atomize well at pressures too low, yet at higher (normal) pressures those 50's will run rich. The only real solution is to get a chip made to run 50's.
SeattleSy#1255
Category 5 Conservative
umm...you can even get the chip, but if your fuel pump isn't upgraded...your AFPR, injecters, and chip is a waste.
Ok,I dont have a chip yet, next purchase, gotta wait for taxes to come back. And I tested my FP last fall and it is putting out plenty of volume, and pressure for the truck, it may have a Walboro in it, I'm not sure, and the guy I bought it from didn't know either (i'm the 3rd owner). But even without the chip I should be able to get it to stoich by adjusting the FP. Was just wondering if anyone could tell me what the readings above were telliing me, I drove it a bit this morning and it seemed that at about 1/2 throttle under a load it was going closer to 128, so I think she's getting pretty close.
As far as the chip goes how did you guys do it, did you install all your mods first and then get the chip, or did you get your chip and then have it re-burned every time you added a mod???
Thanks,
Dewey
