am i understanding this correctly?
spooldup
Super Member
The first major revision is that these programs will all have wideband 02 datalogging capabilities, by putting the 0-5 volt output of your sensor to the F14 port on the ECM. It will display values correlating to your sensor's input in the AFR field in the scan tool (more to come on this as soon as these programs make it out there).
I was reading this info on the 50# ultimate. My understanding of this is that we can install a wideband o2 and it will display on datamaster? That's cool if i am getting this right. So if i just had my chip updated last week (wich i did) is this new feature in it? If not when do we have to send them back in for adjustment?
smeagol
Yes, it will display on datamaster.
Who updated the chip for you? Just gotta make sure what revision it is, should work fine, just gotta make sure you have an accurate AFR vs Datamaster reading correlation.
