Amp wire routing?
MRKING
New Parts for Old Trucks
Re: Amp wire routing?
Theres a grommet on the pass side that the radio antenna comes through . You can easily puncture a hole smaller then the wire in it .
Their is a capped hole in firewall under the breakbooster (it closer to the driverside fender and easier to rech with the finder well out) I beleive its for the clutch when so equiped. Pop the metal insert out (its glue it with caulking), put in a gromet and run your wire. I think I used a valve cover gromet, but I wouldn't be surpise of 1/0 Gromet fit it.
FYI I actually run my stereo power wire through a plate under my drivers seat (under the carpet).
Amp meter takes 2 wires and they are usually unfused. Just be very careful. If they short together, no harm just the meter doesn't work. Short to something else and fireworks. can be tricky knowing where to hook up so the meter works both ways, as-it-were. But that's just me being picky...
Hmmm, are you talking about a voltmeter?
Ah, never thought of that. I'll bet yur correct, thanks. Old school strikes again...:)
