another 3bar map ?
jbone
I feel kinda stupid for asking this as Im sure its been asked before (I did a search but got tired of looking through thousands of threads) why exactly do we need to use a 3bar map when going over stock boost levels? Friends of mine disagree that it is needed, one of them has a GN and is running 22-25 psi with a 2bar map. When I tell him and others that I need one if im gonna "up" my boost they tell me I dont need it but I dont know enough to argue the point. thanks for the help as always
RwD*eaT3r
Re: another 3bar map ?
Our syty"s Use speed density/ manifold pressure to determine how much air is getting into our engine while a GN relies on a Maf System to measure the air going into the engine.A 2 bar can only read up to 14.7 psi while a 3 bar can red up to something like 29 psi. Hopes this clarifies it for you.
SY756
If you run a 3 bar map you will need a 3 bar chip. You can't run a 2 bar chip with a 3 bar MAP, and vice versa. Like said above the 2 bar map only reads to about 15psi. If you go over 15psi the computer doesn't know it and you will probably start running lean. Sure, you can run higher boost with a 2 bar but it's not recommened. You might could get by with up to 16-17 psi with turning up the FP but I wouldn't go any higher than that. JMO
A GN's 2 bar map is for the boost gauge, is does not connect to the ECM. Also a GN uses open loop boost control so it doesn't have the ability to correct boost through feedback. Its boost control (duty cycle) is based on TPS and RPM (it has the abaility to pull back boost in 3rd and 4th gear) The GN ECM has no idea how much boost the turbo is making only how much air is going through the MAF sensor.
jbone
I was also told that using the afpr I could safely increase boostwithout going too lean. (Not that I would) but how far can you go increasing fuel pressure until it isnt safe or until increasing fuel pressure wont work anymore, and why?.
QUICK STORM
B.A.M.F. BMW Tech
it depends, too much fuel pressure will flood the motor with fuel and hurt power too little fuel pressure, will cause a severe lean condition and knock like crazy, then BOOM. time for a rebuild. usually with stock injectors fuel pressure is set to 42, with the vacuum disconnected. now its a different story with larger injectors. biggest thing you wanna stay away from is maxing out the duty cycle of the injector, cuz it could burn it up.
Ian Turgeon
Cascading Inspiration
Right , with a 2 bar, after 14.7psi the injectors wont compensate, they will spend the same amount of time open for 80psi as they did for 14.7psi. The only thing that actually delivers more fuel (does upping pressure actually result in more flow?) from there on up is the fuel pressure regulator. Might as well switch to a carb if your gonna tune using that method.
So even if you could provide enough fuel at your targeted (lets say 25psi), then everywhere between 14.7 and 24 is gonna be pig rich because your delivering the same fuel needed for 25psi across the board (disregaurding fuel pressure variation).
With the 2 bar you can also forget about having a boost limit controlled by the ecm to save your ass, theres no way to put a safegaurd for your motor at 20, 25, 30 psi to prevent overboost situations.
We have the technology, it would foolish not to use it.
