Methuselah
I have made the small two-transistor RS232 level convertor that you may have seen as a quick alternative to the max232 for home-made cables. http://www.home.aone.net.au/techedge/vehicle/2tran.gif
Anyhow, with the notebook powered by an A/C adapter plugged into the garage (while the truck is stationary of course) the notebook connects fine with no link timing. When the notebook is unplugged and run off its battery the link fails and it cannot reconnect (no amount of timing fixes this). When I put an inverter in the truck run from the cigarette lighter socket, it connects fine.
But, when I shift the truck into any gear it loses the connection. When driving the software can reconnect.
Clearly there is an electrical issue here, but I am not clear on what it is or how to solve it.
I probably do have some grounding demons since I see the oil pressure needle go wacky before I start the truck up.
Suggestions? Thanks.
