When I record a run,sometimes I'll just drive around for a minute or so and let it record,but when I play it back,it will only play it for 10 seconds or so.So how do I get it to play back the entire run that I just recorded?
This is usually caused by the record mode being switched "OFF" while collecting data. In this case, only the last 50 records are saved when record mode is exited. Use the Red/green button on the right that says Rec On or Rec Off and make sure it says "Rec On"
read this under appendix "C" in the manual...as well as chapter 6
