Another Datamaster thread
mmp142965
say it like you spell it!
Re: Another Datamaster thread
Jimmy said:
typhoon147@charter.net
I won't be able to look at it until about 1:30 am
can you look at mine too?
mmp142965
Jimmy said:
Could you send me a complete .uni file?
yea man you got it. just didnt want to show up in your in box uninvited. Thanks!
Jimmy
Banned
Is your IC pump hardwired? It's not showing that it's turned on,and your IAT's are kinda high.Only making 11-13 lbs boost WOT,so may have a boost leak or need wastegate adjustment.
Spark retard looks fine,fueling is good.The stock chip sux.
mmp142965
IC pump is hard wired. 11-13lbs of boost is the EBC. Untill i can loosen the wastegate rod a little I have it set as low as it will go. I know the IAT's look high...its a johnson pump too. what gives? The voltage seems low, that might affect the pump output?
Jimmy
Banned
Once the IC gets heatsoaked,it usually stays in the 125 degree range,so it's really no biggie.Generally the high intake temps will cause knock,but yours isn't knocking at all. :tup:
Jimmy
Banned
Olskoolturbo said:
Jimmy I sent you that file.
Well Christian,in the file you sent it isn't overboosting.Just pull the ECM-B fuse and all the codes will be reset
If you are running the stock wastegate without a cat,it's gonna overboost.Get an external or put a cat on it.
Looks like it's running too rich and shifting too high. adjust your TV cable,and turn down your FP a bit.I think your spark retard is because of the richness.You want your 02's in the 900ish range @ WOT,not 1000+ ;)
Olskoolturbo
Use the force to fix it
I'll try that this morning and see if I can get another file within the next day, BTW if I want to drive it hard I have to shift 1,2,D the way this trans is set up. I guess I will have to pop the lever alittle quicker!
