cat-vi
Ty Wannabe
Hi,
I got a idle problem, engine is hunting until it dies, too keep it running I have to pump the gas pedal just like a old caburated engine.
As soon as I have slightly load at the engine by running up a hill, it is running very smothly all the way down to abt. 1000 rpm. I have searched in the forums for idle problem but can not quite find anny thread covering my problem, what is the first thing I should check up, should I try to replace the "Idle Control Motor" or is there annything else I should check up first?
Another issue I have is, at wide open throttle the throttle position read 91,5%, when I look at the throttle blade they are 100% open, should I purchase a new throttle position sensor as well or is there a way to adjust this on the software for the ecm (bigstuff3)
Any advice would be highly appreciated.
